# Plane Detection in ROS
In this tutorial, you will learn how to exploit the Plane Detection capabilities of the ZED SDK to detect the planes in the environment where a ZED camera is operating.
## Start a plane detection task
The ZED ROS nodelet subscribes to the topic `/clicked_point` of type [`geometry_msgs/PointStamped`](http://docs.ros.org/en/noetic/api/geometry_msgs/html/msg/PointStamped.html), usually published by RViz.
When a message on the topic `/clicked_point` is received, the node searches for the first plane hit by a virtual ray starting from the camera optical center and virtually passing through the received 3D point.
If a plane is found, its position and orientation are calculated, the 3D mesh is extracted and all the useful plane information is published as a custom [`zed_interfaces/PlaneStamped`](#detected-plane-message) message on the topic `/<camera_name>/<node_name>/plane`.
A second message of type `visualization_msgs/Marker` with information useful for visualization is published on the topic `/<camera_name>/<node_name>/plane_marker` in order to display the plane using a [Marker display plugin](http://wiki.ros.org/rviz/DisplayTypes/Marker) in RViz.
![Planes](/_fern-img/919bdc4eab7e6567289012e4a231dbcecaf6e7291abedd7fd90a0041321ea1f3.webp)
![Planes no clouds](/_fern-img/b258b50316f98c872ed42cfe8b2f5085a907ae45528237e13eba87326766da26.webp)
### Logging
When a plane detection is started, the log of the ROS wrapper will show the following information:
[ INFO] [1650968720.874632336]: Clicked 3D point [X FW, Y LF, Z UP]: [1.99638,0.382713,0.483519]
[ INFO] [1650968720.874707228]: 'map' -> 'zed2i_left_camera_optical': {-0.023,0.014,-0.130} {-0.469,0.554,-0.507,-0.465}
[ INFO] [1650968720.874751279]: Point in camera coordinates [Z FW, X RG, Y DW]: {-0.676,-0.546,1.774}
[ INFO] [1650968720.874803341]: Clicked point image coordinates: [442.699,182.342]
[ INFO] [1650968720.930809324]: Found plane at point [1.996,0.383,0.484] -> Center: [1.255,0.649,0.199], Dims: 1.458x1.225
## RViz
The RViz GUI lets you easily start a plane detection task and displays the results of the detection.
### Start a plane detection
To publish a `/clicked_point` message and start a plane detection, the `Publish Point` button must be enabled and a point in the 3D view or the camera view must be clicked.
![Publish Point](/_fern-img/6a493eb7a05c0cbcdb1e935470159586918be7ea7888dbefd576f9444dd5d4d8.webp)
### Configure RViz to display the results
The Marker plugin allows you to visualize the information of the detected planes.
![Marker](/_fern-img/e47bc105392e0eb16a926b56f54837faabea8c9664614e9707a526df81bd44ca.webp)
Key parameters:
* `Marker Topic`: The topic that contains the information relative to the detected planes: e.g. `/zed2i/zed_node/plane_marker`
* `Queue Size`: The size of the message queue. Use at least a value of `2` to not lose messages.
* `Namespaces`: The list of available information:
  * `plane_hit_points`: Select to display a sphere where the click has been received.
  * `plane_meshes`: Select to display all the meshes of the detected planes.
## Detected Plane message
The `zed_interfaces/PlaneStamped` message is defined as:
# Standard Header
std_msgs/Header header
# Mesh of the plane
shape_msgs/Mesh mesh
# Representation of a plane, using the plane equation ax + by + cz + d = 0
shape_msgs/Plane coefficients
# Normal vector
geometry_msgs/Point32 normal
# Center point
geometry_msgs/Point32 center
# Plane pose relative to the global reference frame
geometry_msgs/Transform pose
# Width and height of the bounding rectangle around the plane contours
float32[2] extents
# The polygon bounds of the plane
geometry_msgs/Polygon bounds
