# Plane Detection Overview
## Introduction
With the 3D information of the environment, the ZED camera can estimate the position of the planes present in the scene.
To detect a plane, positional tracking needs to be enabled with `zed.enablePositionalTracking()`. Also, a plane can be detected only if the tracking state of the camera is `OK`.
Therefore, the procedure for detecting a plane is as follows:
* Enable the positional tracking module
* Grab an image from the ZED
* Check that the tracking state is `OK`
* Estimate a plane position.
## Detecting Planes
To estimate a plane position, you will need to use the `findPlaneAtHit` function and pass the 2D coordinates of a target pixel where you want to find its support plane. Below is an example of code that can be used to estimate the plane passing through the 3D point of pixel `coord = (u,v)`:
**`C++`**
```cpp C++
sl::Plane plane;
sl::uint2 coord; // Fill it with the coordinates taken from the full size image
while (zed.grab() == ERROR_CODE::SUCCESS) {
  tracking_state = zed.getPosition(pose); // Get the tracking state of the camera
  if (tracking_state == POSITIONAL_TRACKING_STATE::OK) {
    // Detect the plane passing by the depth value of pixel coord
    find_plane_status = zed.findPlaneAtHit(coord, plane);
**`Python`**
```python Python
plane = sl.Plane() # Structure that stores the estimated plane
coord = sl.uint2() # Fill it with the coordinates taken from the full size image
while zed.grab() == sl.ERROR_CODE.SUCCESS:
  tracking_state = zed.get_position(pose) # Get the tracking state of the camera
  if tracking_state == sl.POSITIONAL_TRACKING_STATE.OK:
    # Detect the plane passing by the depth value of pixel coord
    find_plane_status = zed.find_plane_at_hit(coord, plane)
**`C#`**
```csharp C#
sl.PlaneData plane = new sl.PlaneData();
sl.PlaneDetectionParameters planeParams = new sl.PlaneDetectionParameters();
Vector2 coord = new Vector2();
sl.RuntimeParameters runtimeParameters = new sl.RuntimeParameters();
while (zed.Grab(ref runtimeParameters) == sl.ERROR_CODE.SUCCESS) {
    sl.Pose pose = new sl.Pose();
    sl.POSITIONAL_TRACKING_STATE tracking_state = zed.GetPosition(ref pose);
    if (tracking_state == sl.POSITIONAL_TRACKING_STATE.OK)
       sl.ERROR_CODE find_plane_status = zed.FindPlaneAtHit(ref plane, coord, ref planeParams);
If it succeeds the function stores the detected plane in a `sl::Plane` object, which includes useful information such as 3D position, normal, polygon boundaries and plane type (vertical/horizontal).
## Accessing Plane Data
The `sl::Plane` class contains all the information for defining the plane in space such as normal, center and equation. To access this information use the getter of the class. For example:
**`C++`**
```cpp C++
if (find_plane_status == ERROR_CODE::SUCCESS) {
  sl::float3 normal = plane.getNormal(); // Get the normal vector of the detected plane
  sl::float4 plane_equation = plane.getPlaneEquation(); // Get (a,b,c,d) where ax+by+cz+d=0
**`Python`**
```python Python
if find_plane_status == sl.ERROR_CODE.SUCCESS:
  normal = plane.get_normal() # Get the normal vector of the detected plane
  plane_equation = plane.get_plane_equation() # Get (a,b,c,d) where ax+by+cz+d=0
**`C#`**
```csharp C#
if (find_plane_status == ERROR_CODE.SUCCESS) {
  Vector3 normal = plane.PlaneNormal; // Get the normal vector of the detected plane
  Vector4 plane_equation = plane.PlaneEquation; // Get (a,b,c,d) where ax+by+cz+d=0
For AR purposes it can be useful to get the `Transform` of the detected plane according to the global reference frame. For example to place an object close to a wall or to transform the global reference frame center to the plane center. This transform is accessible as follows:
**`C++`**
```cpp C++
  // Get the transform of the plane according to the global reference frame
  sl::Transform plane_transform = plane.getPose();
**`Python`**
```python Python
if find_plane_status == sl.ERROR_CODE.SUCCESS :
  # Get the transform of the plane according to the global reference frame
  plane_transform = plane.get_pose()
**`C#`**
```csharp C#
  Vector3 translation = plane.PlaneTransformPosition;
  Quaternion rotation = plane.PlaneTransformOrientation;
### Convert Plane to Mesh
The detected plane can be converted to a `Mesh`. Converting it to a mesh can be useful when highlighting a plane in the scene. To get the mesh of the plane, call:
**`C++`**
```cpp C++
 sl::Mesh mesh = plane.extractMesh();
**`Python`**
```python Python
mesh = sl.Mesh()
mesh = plane.extract_mesh()
**`C#`**
```csharp C#
Vector3[] planeMeshVertices = new Vector3[65000];
int[] planeMeshTriangles = new int[65000];
int numVertices = 0;
int numTriangles = 0;
zed.ConvertHitPlaneToMesh(planeMeshVertices, planeMeshTriangles, out numVertices, out numTriangles);
## Detecting Floor Plane
With the 3D information of the environment, ZED cameras can estimate where the ground floor is in a scene.
![image](/_fern-img/e3af0e16c50e9f91b02bf12d5c9f8a6cc012a0c6b2071aa045a163888afc69c5.webp)
## Getting Floor Plane
The floor plane can be automatically detected by calling `findFloorPlane` instead of `findPlaneAtHit`. Apart from storing the plane in a `sl::Plane`, this function will also store the transform between the floor plane frame and the camera frame.
This transform can be used to reset the tracking and align it with the floor plane frame as follows:
**`C++`**
```cpp C++
sl::Plane plane;
sl::Transform resetTrackingFloorFrame;
find_plane_status = zed.findFloorPlane(plane, resetTrackingFloorFrame);
  // Reset positional tracking to align it with the floor plane frame
  zed.resetPositionalTracking(resetTrackingFloorFrame);
**`Python`**
```python Python
plane = sl.Plane()
resetTrackingFloorFrame = sl.Transform()
find_plane_status = zed.find_floor_plane(plane, resetTrackingFloorFrame)
  # Reset positional tracking to align it with the floor plane frame
  zed.reset_positional_tracking(resetTrackingFloorFrame)
**`C#`**
```csharp C#
PlaneData plane = new PlaneData();
float playerHeight = 0;
Quaternion priorQuat = Quaternion.Identity;
Vector3 priorVec = Vector3.Zero;
ERROR_CODE find_plane_status = zed.FindFloorPlane(ref plane, out playerHeight, priorQuat, priorVec);
    zed.ResetPositionalTracking(plane.PlaneTransformOrientation, plane.PlaneTransformPosition);
This code can be simplified by using `PositionalTrackingParameters::set_floor_as_origin` to align the positional tracking reference frame on the ground floor.
**`C++`**
```cpp C++
positional_tracking_parameters.set_floor_as_origin = true;
RuntimeParameters runtime_parameters;
runtime_parameters.measure3D_reference_frame = REFERENCE_FRAME::WORLD;
sl::Mat cloud;
while (zed.grab(runtime_parameters) == ERROR_CODE::SUCCESS) {
  zed.retrieveMeasure(cloud, MEASURE::XYZRGBA);
  // The point cloud is aligned on the floor plane.
  // A threshold on the height could then be used as a simple object detection method
**`Python`**
```python Python
positional_tracking_parameters = sl.PositionalTrackingParameters()
positional_tracking_parameters.set_floor_as_origin = True
zed.enable_positional_tracking(positional_tracking_parameters)
runtime_parameters = sl.RuntimeParameters()
runtime_parameters.measure3D_reference_frame = sl.REFERENCE_FRAME.WORLD
cloud = sl.Mat()
while zed.grab(runtime_parameters) == sl.ERROR_CODE.SUCCESS:
  zed.retrieve_measure(cloud, sl.MEASURE.XYZRGBA)
  # The point cloud is aligned on the floor plane.
  # A threshold on the height could then be used as a simple object detection method
**`C#`**
```csharp C#
trackingParams.setFloorAsOrigin = true;
runtimeParameters.measure3DReferenceFrame = REFERENCE_FRAME.WORLD;
Mat cloud = new Mat();
while(zed.Grab(ref runtimeParameters) == ERROR_CODE.SUCCESS)
    zed.RetrieveMeasure(cloud, MEASURE.XYZRGBA);
The estimation of the floor plane can be refined by passing prior parameters (such as prior height or orientation) to
the `findFloorPlane` function. For additional details on these parameters, please check out the
[API Reference](https://www.stereolabs.com/docs/api/classsl_1_1Camera.html).
