Connection An MQTT broker is a program that offers publisher-subscribers capabilities to distribute messages from applications connected to it. Applications running on the device can connect to a broker to send logs, data and answer to remote functions. Using the C++ API When using the C++ API you can use MQTT through build-in functions: publishOnTopic: send data to a topic/label subscribeToTopic: listen for new data on a topic/label Using the Python API When using the Python API you can use MQTT through build-in functions: publish_on_topic: send data to a topic/label subscribe_to_topic: listen for new data on a topic/label
