Accessing Raw NV12 Buffers
This guide explains how to access raw NV12 image buffers directly from the ZED SDK using the RawBuffer API. This is an advanced, zero-copy interface designed for performance-critical applications.
Warning: This is an advanced low-level API. Improper use can crash the Argus stack responsible for camera operations or destabilize the system. Use this API only if you understand NVIDIA® multimedia buffer handling.
Note: This API is only available starting from ZED SDK version 5.2. It is supported on NVIDIA® Jetson™ platforms with GMSL2 cameras. It is not available on x86 platforms, with USB cameras, or using SVO and Network streaming as input sources.
Overview #
The RawBuffer API provides direct access to native NvBufSurface buffers from the ZED X camera capture pipeline. Instead of copying image data, this API gives you a pointer to the underlying buffer, enabling zero-copy integration with NVIDIA multimedia frameworks.
Use Cases #
This API is particularly useful for:
  • GStreamer pipelines – Feed camera frames directly into GStreamer without memory copies
  • NVIDIA DeepStream – Low-latency inference pipelines for real-time object detection
  • Custom CUDA processing – Direct GPU access to camera buffers
  • Hardware video encoding – Direct integration with NVENC
Enabling the API #
The RawBuffer API is disabled by default. To enable it, define SL_ENABLE_ADVANCED_CAPTURE_API before including the ZED SDK header:
#define SL_ENABLE_ADVANCED_CAPTURE_API
#include <sl/Camera.hpp>
Code Example #
#include <nvbufsurface.h>  // NVIDIA buffer surface API
using namespace sl;
int main() {
    Camera zed;
    InitParameters init_params;
    init_params.camera_fps = 30;
    if (zed.open(init_params) != ERROR_CODE::SUCCESS) {
        return -1;
    while (true) {
            RawBuffer raw;
            if (zed.retrieveImage(raw) == ERROR_CODE::SUCCESS) {
                if (raw.isValid()) {
                    // Get NvBufSurface pointers (zero-copy)
                    void* nvbufLeft = raw.getRawBuffer();
                    void* nvbufRight = raw.getRawBufferRight();
                    // Cast to NvBufSurface* for use with NVIDIA APIs
                    NvBufSurface* surfLeft = static_cast<NvBufSurface*>(nvbufLeft);
                    NvBufSurface* surfRight = static_cast<NvBufSurface*>(nvbufRight);
                    // Access buffer properties
                    uint64_t timestamp = raw.getTimestamp();
                    unsigned int width = raw.getWidth();
                    unsigned int height = raw.getHeight();
                    // Process the NV12 buffer with your pipeline...
                    // Example: feed to GStreamer, DeepStream, or custom CUDA kernel
                    // Buffer is automatically released when 'raw' goes out of scope
    zed.close();
    return 0;
Integration with DeepStream #
For NVIDIA® DeepStream integration, you can pass the NvBufSurface object directly to your inference pipeline:
#include <nvds_meta.h>
// In your DeepStream pipeline loop:
RawBuffer raw;
if (zed.retrieveImage(raw) == ERROR_CODE::SUCCESS && raw.isValid()) {
    NvBufSurface* surface = static_cast<NvBufSurface*>(raw.getRawBuffer());
    // Feed surface to DeepStream batch
    // surface->surfaceList[0] contains the NV12 frame data
    // Process with nvinfer, nvtracker, etc.
Important Warnings #
⚠️ DO NOT manually destroy the NvBufSurface (e.g., do not call NvBufSurfaceDestroy, NvBufSurfaceUnMap, etc.). The buffers are owned and managed by the SDK. Manual destruction will cause crashes or undefined behavior.
  • The SDK manages the buffer memory – you only have read access
  • Hold the RawBuffer for as short a time as possible to avoid blocking the capture pipeline
  • Currently, only RAW_BUFFER_TYPE::NVBUFSURFACE (NVIDIA® Argus native buffers) is supported
  • This API is available only on NVIDIA Jetson platforms with GMSL2 cameras
Buffer Format #
The raw buffers contain NV12 formatted image data:
  • Y plane: Full-resolution luminance data
  • UV plane: Half-resolution (2x2 subsampled) chrominance data
This is the native capture format from the ZED X sensor, providing maximum performance for pipelines that work with NV12 directly.
