Setting up the ZED X One Monocular
This guide explains how to set up a ZED X One Monocular camera on an NVIDIA® Jetson™ platform and use it to retrieve image and inertial data.
Install the GMSL2 driver #
⚠️ Important: This procedure is valid only for ZED Box Orin, ZED Box Mini, or official NVIDIA® Jetson™ development kit platforms equipped with a ZED Link GMSL2 Capture Card. If you are using a different GMSL2 system, please refer to the specific installation instructions provided by your hardware manufacturer.
ZED X One cameras require a GMSL2 driver to operate correctly. This driver configures the GMSL2 device and is hardware-dependent.
Download the appropriate driver from the ZED X Driver download page.
📌 Note: Always verify the latest driver version available on the download page. We recommend installing the most recent version.
Select the driver matching your hardware configuration and install it:
sudo dpkg -i stereolabs-<board>_X.X.X-<deserializer>-L4TZZ.Z.Z_arm64.deb
Where:
X.X.Xis the driver version<board>is the board model<deserializer>is the deserializer typeL4TZZ.Z.Zis the Jetson™ Linux version (corresponding to your JetPack version)
Example: For ZED X Driver v1.3.2 on L4T 36.4.0 (JetPack 6.2) with the Stereolabs ZED Link Duo GMSL2 Capture Card:
sudo dpkg -i stereolabs-zedlink-duo_1.3.2-LI-MAX96712-all-L4T36.4.0_arm64.deb
📌 Note: If the installation fails due to missing dependencies, install
libqt5core5a:sudo apt install libqt5core5a
After installation, reboot your NVIDIA® Jetson™ platform.
For troubleshooting, refer to the ZED Link troubleshooting guide.
Use the ZED X One with the ZED SDK #
The ZED SDK includes built-in support for data acquisition from a ZED X One monocular camera using the sl::CameraOne class, allowing you to open and manage the camera directly through the SDK without relying on external tools.
Install the ZED SDK #
The ZED SDK enables processing of image data from ZED X One cameras in monocular mode. The sl::CameraOne class provides the core functionality to retrieve raw and rectified images, as well as inertial data.
To get started, download and install the ZED SDK on your NVIDIA® Jetson™ platform.
Sample code to open and use the ZED X One monocular camera #
#include <sl/CameraOne.hpp>
using namespace sl;
// Set the input from stream
InitParametersOne init_parameters;
// Set any InitParametersOne as needed to configure the camera settings
sl::CameraOne zed_one;
// Open the camera
ERROR_CODE err = zed_one.open(init_parameters);
exit(-1);
Mat bgra;
while (!exit_app) {
if (zed_one.grab() == ERROR_CODE::SUCCESS) {
zed_one.retrieveImage(bgra); // Retrieve the BGRA image (default format)
// Any processing
// Close the camera
zed_one.close();
import pyzed.sl as sl
zed_one = sl.CameraOne()
# Set the input from stream
init = sl.InitParametersOne()
# Set any InitParametersOne as needed to configure the camera settings
# Open the camera
err = zed_one.open(init)
exit(1)
bgra = sl.Mat()
while not exit_app:
if zed_one.grab() == sl.ERROR_CODE.SUCCESS:
zed_one.retrieve_image(bgra) # Retrieve the BGRA image (default format)
# Any processing
# Close the camera
zed_one.close()
For more details on using the ZED SDK with monocular ZED X One cameras, refer to the ZED SDK API documentation.
Use the ZED X One with NVIDIA® Libargus Camera API #
The camera can be opened using the Libargus Camera API, the tools provided by NVIDIA® on Jetson™ to open cameras connected via GMSL2 and CSI.
Make sure the multimedia API is installed:
sudo apt install nvidia-l4t-jetson-multimedia-api
Then compile the camera sample:
cp -r /usr/src/jetson_multimedia_api/* ./
sudo apt install libgtk-3-dev
cd argus
mkdir build && cd build && cmake .. && make
cp apps/camera/ui/camera/argus_camera ./
./argus_camera
Use the ZED X One with GStreamer #
Use the Stereolabs zedxonesrc source element
Please refer to the ZED GStreamer plugin documentation to leverage the full capabilities of the ZED X One camera.
Use the NVIDIA® nvarguscamerasrc source element
To open the camera using the nvarguscamera GStreamer plugin, run:
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1200, framerate=30/1' ! nvvidconv flip-method=0 ! 'video/x-raw, format=(string)I420' ! xvimagesink -e
Please refer to the NVIDIA® documentation for more information.
Use the ZED X One with the open source driver ZED X Open Capture #
To use the ZED X One capture open source API, go to https://github.com/stereolabs/zedx-one-capture.
Compile the library, then modify the sample to fit your application.
The library is based on the multimedia API from NVIDIA®.
📌 Note: Support for retrieving IMU data will be available in a future release.
Use the ZED X One with ROS 2 #
The ZED ROS 2 wrapper supports monocular ZED X One data publishing.
When launching the ZED ROS 2 node, set the camera_model parameter to one of the available models: zedxonegs, zedxone4k. For example:
ros2 launch zed_wrapper zed_camera.launch.py camera_model:=zedxonegs
or
ros2 launch zed_wrapper zed_camera.launch.py camera_model:=zedxone4k
For more details on using the ZED ROS 2 wrapper, refer to the ZED ROS 2 documentation.
